Online: GGUser260
oil leak from primary
  • numbers
    numbers
    Hi Guys - i replaced the inner primary bearing on my 03 WG and after reassemby found it leaked oil - i pulled the primary apart again and replaced the oil bearing and put it back togrther and still getting an oil leak from where the inner primary meets the tranny - before i pull it apart again has anyone got any ideas? cheers, Numbers
  • numbers
    numbers
    i replaced the seal that sits behind the main primary bearing with a new oil seal
