Online: GGUser260
Overheating Softail
  • Vetman
    Vetman
     I am running in my new softail standard and i have 1400klms on the clock. The other night i had to travel through brisbane city and i got  caught in heavy traffic. After about 15 minutes of stop then go for 50 m and then stop again i could feel the heat comming up from the engine nearly burning my inner thighs, Then i got free and took off on the highway and it cooled down. It was about 25 degrees. Would i have done any damage to the engine since i am only still running it in?
    Morgs
  • Vetman
    Vetman
    so that is a ' no need to worry'?
    Morgs
  • Bobtail
    Bobtail
    Soon after your first service or at first service get a stage one Air Cleaner, slip on muffs, Sepst tuner and a good synthetic oil & your heat probs will be no more or at least greatly reduced, bonus is a heap more horses....If you get it done by a dealer warranty should not be an issue...
    Methinks that in the long run that excssive heat will have a detrimental effect on the engine...Partic if you ride a lot...
    Bt
  • Windy
    Windy
    You, Mr Vetman,  are in serious trouble, with temps you have achieved you have without doubt done permanent damage to the inner left Petuary Crank Valve and also certainly both the units upper & lower bearings.
    No amount of clean oil or care will now prevent this suffering catastrophic failure in the near future and without doubt, it will happen during a hot summer run.
    Harley have been well aware of this issue for some time and have done nothing - as is usual HD policy they pretend it does not exist.
    Good luck to you!
