Online: GGUser744
dyno tune
  • The Ox
    The Ox
    Hi do you think my bike will run better if i get it dynotuned. I have the stage one upgrade with vance and hines big radious pipes, sepst and sreaming eagle heavy breather. Will it get rid of the decel popping.
    Without a doubt it will help. You just need to find a good tuner to do it !
  • The Ox
    The Ox
    Thanks speedzter
  • Yositime
    Yositime
    Yes, world of difference over stock. Its when you start talking about is it worth the money or what tuner the best bang for you buck when the discussion gets lively.
    Ox mentioned he has the SEPST already, so that decision is easy !
