Online: GGUser260
master cylinder leaking
  • JD
    JD
    any one had any problems with their master cylinder leaking? my front and rear seem to be
  • motor_head
    motor_head
      Omar!!!  ... did you put the wrong fluid in ..... if so, been there, done that     .... other than that, no idea.
  • JD
    JD
    not change them add too them did nil to them. just was loooking at them and seen the paints bubbled around them
  • whiteyluvsrum
    whiteyluvsrum
    both of mine leaked and bubbled.
  • JD
    JD
    you know I never bag HD but you think they get the brakes right , seems like its a standard thing can you get after market ones no point getting the same if they just go again
  • JD
    JD
    well i looked at the spon sites at the top of the site figure i give them so money fuck there sites are hard to search for what you need.
    hey Hill do the chrome ones leak ?
  • pedrod59
    pedrod59
    I had the same problem earlier on. Posted a threat about it here, and received a lot of replies with some great ideas..thanks to you all.
    Someone added some photos of what to do. I am not sure how to paste the link to that thread but it may help ya, but if you searched Leaking Master Cylinder you should find it.
    My front brake master cylinder was leaking. Got the master cylinder as level as possible and removed the cap, it appeared to be overfull, so I used a clean syringe and removed some brake fluid, cleaned the seal and cap very well, put it all back together and never had a problem since.
    Good luck with it..
  • JD
    JD
    I am going to flush the the brakes then do as you posted and if if that dont work i am going to try tts
