Online: GGUser744
Great Ocean Road
  • Henry
    Henry
    Hi Guys
    I went for a ride today down the GO road, great weather and a great ride, but if you are thinking of going there in the next couple of weeks, watch out for the loose stones from the roadworks that they were doing today at Moggs Creek, for around 4 corners, Cumberland river about 300m, and a couple of klms before Wye river. it's not hot mix either just the bitumen with 20mm stones on top and rolled in.
  • 48fan
    48fan
    thanks for the heads up
    might just save some ones life .
    was there any signage ?
  • PK2
    PK2
    Used to ride GOR heaps years ago, then they put lines down the middle and changed most of it to 60 and 80 and wrecked a sensational road......
  • HOG-JOCKEY
    HOG-JOCKEY
    Great story on how it was built after the war using returned soldiers..
    Sort of like a remembrance drive..
  • trailcutter
    trailcutter
    yep..........
    lookout for bloody wallabys as well ..
    hit one about 3 k east of loch ard.........poped outta the scrub at warp speed , headbutted front disc during youthenaisa program.
    80 kph..just lucky it happened on the only dry patch of road that day..
    warped disc and intermittent front brakes ,,
    i,ve hit my share on dirt / adv bikes
    but very happy did,nt chuck the flhrc down road..
  • boxa
    boxa
    Coming back from phillip island , came round a bend , Only to see one sat in my path , wonder if it was the same one , Lucky i was taking it easy
