Modified Exhaust Baffles.
  • pan head
    pan head
     Got a 1993 883 Sporty with slash cut pipes, decided to take the baffles out so it would sound like a Harley.   But then it started coughing and spitting especially when cold.  Then I read without baffles you have the chance of  burning valves.  So I decided to have the baffles opened up and put back in.
      Still farting and spitting, anyone got any suggestions.  Or is this how its ment to be.......
  • kingchops
    kingchops
    It's most likely running lean because of the increased exhaust flow.   You may need to tune your carb.  Also check that your plugs are not fouled.
  • pan head
    pan head
    Thanks for that
    I seen these cones on ebay, was going to give them a go, fit up near the header.
     STAINLESS STEEL TORQUE CONES
    Straight pipes sound sweet, but for street use they're a performance disaster!
    Here's an inexpensive way to get back some of that lost horsepower and gas mileage without affecting the sound.
    Simply fit inside header pipes.BRAND NEW
  • 308bever
    308bever
    how do they work? are they any good? how does a restricter help?
  • pan head
    pan head
    Not sure but I found them on ebay,
  • Damon
    Damon
    Just retune the carby and its done properly. Not worth a lunched engine playing around with other supposed solutions when the right one is both clear and affordable.
