Online: Stuart
rocker warning
  • kiteman
    kiteman
    I'll ask the question on the Yankee forum and see what comes up. Will let ya know.
    what sort of wabble there sambo.... there could be any number of things that cause it, all the way down to loose fitting jacket which results in wind buffeting filtering through the arms and causing steering wobble. Could also be problem with front tyre (ask Snagger about his V-Rod problems) or uneven levels of oil in the forks.
    Ask your dealer and they are likely to wash their hands by saying you shouldn't be doing those speeds , or bike is not designed for those speeds
  • Paul.C
    Paul.C
    Have you riddin a bike at that speed before?
    I know at around 240 on a sports bike you start to really get smashed by the wind on your back... like Uncle said, a bad fitting jacket could be all it takes
  • Paul.C
    Paul.C
    nice bike,  i had a s4rs before my fatty
    I got the harley to slow down and havent been over 140 so iv'e had no probs with it.
  • GREG
    GREG
    Leave the dukes for the young fellas sambo, enjoy the crusier for what it is.
  • TNT
    TNT
    Well HD did compromise handling for looks with that 240 rear tyre but don't it look shit hot
