Tank Lift in Perth?
  • evileye
    evileye
    Hi
    Does anyone know who will do a tank lift in Perth on my Iron?  I've checked with Frasers and Supercycles but neither will do it.  I'm hoping to lift the tank by about 2" if possible.  I know some have done it themselves but I'm NO mechanic so that's not an option for me.
  • evileye
    evileye
    Ok guys, point taken. I'll try and find the parts and go from there.
    Thanks
  • 883n Harley Convert
    883n Harley Convert
    Have a look at DK Customs tank lifts, as the other blokes have mentioned its an easy job. I'm useless with the spammers but found it quite simple to do and it looks good!
  • evileye
    evileye
    I can see that the fittings to lift the tank are quite simply and easy to install - I'm thinking of the 2" kit (for my 2012 Iron). What I'm not sure about is the long plastic channel that sits under my tank now, that hides the wiring etc., should that be removed? If so, will the wiring/cables still hide under the tank and within the bike frame?  Or can the plastic channel remain?
  • evileye
    evileye
    Hey Convert, brilliant! Scary, but probably doable.
    Thanks
    883n Harley Convert
    You'll work it out, if I can do it.....anyone can=)
