Online: beaglebasher
Red key light staying on
  • Mainey88
    Mainey88
    When I got the bike back after getting it dyno'd the red key security light on the speedo head says on for a while after start up, it used to go off straight away, a quick rev and she goes out, bike runs OK all else seems fine. Is a problem looming or is this normal
  • Mainey88
    Mainey88
    oh  ,,,,,  its going into frasers next week so will get them to sort it,  They had the TSSM off coz the indicators wernt working but found the TSSM was ok and they put it back on, wonder if that had anything to do with it.
  • Mainey88
    Mainey88
    styx,,, thats mighty helpful mate, done a print out and will check it out
  • Mainey88
    Mainey88
    thanks fellas, I'm on to it now
  • JFE
    JFE
    Mine did it due to the front brake lever being slightly depressed by the wind for a lengthy period of time, thus forcing the rear tail light to be on (which was the error). I slowed down, issue went away.
  • JFE
    JFE
    ...hey, turns out legal speeds cured the problem! Who’d thunk it.
