Going wider on a standard Rear Wheel
  • pan head
    pan head
    Hi, anyone looked at going wider on a original sporty custom rear wheel.
    Currently running a Dunlop 130/90/16    How much wider can you go.....
    Metzler do a 140
    Dunlop 150,  Dealer says it can vary from brands.
    cheers.
  • 883n Harley Convert
    883n Harley Convert
    Pan, I will send you an article from the XLforum regarding wheel increase. You can put a 18 x 4.25 rear wheel on a sporty with no issues! Looks shit hot as well!
    883n Harley Convert
    Here is the thread
    http://www.hdforums.com.au/Default.aspx?tabid=71&forumid=1&postid=387323&view=topic
  • kookie
    kookie
    cheers thanks for that !
    Definitely look into that when the stocky goes.
  • pan head
    pan head
    Thanks for that information, will look into it.
    883n Harley Convert
    There is a bloke on eBay, store named Mototeks.................imports to AUS and does wheels in all shapes, sizes etc!!
  • memfis
    memfis
    Hi mate I have 150 80 16 white walls on my 1200 c
  • als1200
    als1200
    Just had a look at mine, it's 150 too. No wonder it's a prick to get on an off :)
  • pan head
    pan head
    Thankyou, what brand tyre
  • als1200
    als1200
    Dunlop too
