Online: Stuart
Headers rubbing on 48 foward controls
  • sjn25281
    sjn25281
    I have noticed a few times recently when going over bumps in the road that there had been a real clunk in the right foot peg.  I couldn't work out what it was, but..
    When cleaning the bike the other day I saw that there is a patch of paint rubbed off the right forward control footpeg mounting bracket where it comes close to the header pipe.
    Is this normal? Is there possible a problem with a loose engine mount or something which is allowing the engine and therefore exhaust to move around too much?
    Could this be a warranty issue I can claim to get the mount repainted / replaced?
    I'm about to install a set of V&H big radius, and I don't want the rub mark to be visible, and I dont want it to rub on the new pipes.
  • 883n Harley Convert
    883n Harley Convert
    Sounds like a warranty issue to me mate, quite surprised that it is hitting though?
  • 48fan
    48fan
    it is common for the engine mounts to rattle loose on the 48's
    check em
  • Ross
    Ross
    once a week a quick walk around with a set of spanners, bit of a nip and tuck over a Sunday arvo beer, as yet, I haven't had anything loose enough to worry about, but the check is quick and easy, and the added nip on the nut isn't going to hurt.
