Online: Stuart
Heat shield solution for V&H 2-1 pipe (pics)
  • slapster
    slapster
    After a bit of hunting around, I found this "Mr Luckys" heat shield on eBay, 40 bucks delivered. Went out for a fang today & it seems to be effective enough. My right leg feels better for it anyway.
    The fit was easy enough, just a couple of stainless hose clamps.
  • crackers
    crackers
    Dude, if it feels good then more power to you, but from my point of view it seems to be pretty small and am not sure how it would prevent radiant heat to your leg.
    Meh, just curious i guess
  • calum883
    calum883
     get forward controls stop riding it like a pony!!!
