Online:
1 bike 2 looks
1 bike 2 looks
HOG-JOCKEY
Go the 1200 .
Nice thing to play with..
883n Harley Convert
Its not an easy fix, but everything is achievable.
The first one has a grind king logo painted on the tank, takes me back 12-15 years when I was still a skater!!
If you wanted to cycle through, it wouldn't be too difficult. The biggest challenge you will face is the cost of having two sets of parts. You'll need x 2 clutch cables, x 2 idle & accelerator cables, extended wires for the apes, x 2 brake cable and that should get you across the line! If you're talking about changing them regularly; just keep both sets ready to go and do the change over as necessary!!
I actually just took my 14' apes off cuz I got sick of them and im running a broomstick bar at the moment.
Cant be certain but the top one looks like standard bars turned up side down!!
terroristone
I have to agree with ya 883n, those bars do look like stock one's flipped, for the brake line you can have a 6-8 ince joiner made that you can add in when you put the apes on, and get yourself another set of leavers and switch blocks and grips, then it will be a 30 minute swap if your good with tools.
Andrew - T1
HOG-JOCKEY
Dark_Horse
Looks as if the OP has gone the way of the DODO.
And H-S.
You may be able to get your bars Black Chromed.
Call some professionals to find out who can do it.
