Online: speedzter
Do slipons void my warranty
  • jonesy1970
    jonesy1970
    Guys
    If I whack a set of V&H straight shot slipons to my 48, will it void my new bike warranty ?
    Its that or S.E slipons - like the staggered look.
  • Rocky2010
    Rocky2010
    Don't worry about your warranty, just do it
  • 48fan
    48fan
    the dealer should be able to set you straight on that issue
    I got the S&E slip ons fitted at the dealers and when I rang HD insurance they said I wont be covered for them unless I add them to my cover otherwise no probs
    dont know bout the VH
  • 883n Harley Convert
    883n Harley Convert
    This may sound odd, changing the pipes will not void the entire warranty.............................just the pieces you change!!
    Give HD a quick call to confirm!!
