Vrscd Larger tank Install
  • webcke1
    webcke1
    anyone needing info or help on installing the larger Ultimate Engineering tank i'll be more than happy to help you out...just fitted one myself and found it to be very easy
  • cougar
    cougar
    What size is the new tank webcke1?
    and what year VRSCD do you have - wide rear or std?
    wondering if its worth upgrading on mine
  • webcke1
    webcke1
    The tank is made by Ultimate Engineering it's a 21 ltr tank. My bike is a 2006 VRSCD there were two models made that year mine had the smaller tank the later model that crossed over into the night rod special but was still called a night rod that model had the 19 ltr tank the rear of mine is a 180mm but i run a 200mm tyre.......
  • cougar
    cougar
    thanks. mine's an 07 night rod 240 rear and 19l tank. I wouldnt mind a bit more range, but dont think its worth it for 2 litres
  • garyzac
    garyzac
    Where you get these fuel tanks.?......I have  V Rod VRSCSE2 CVO 2006  modle. Mine only holds 14 lts
  • ralphski
    ralphski
    +1 cougar, for 2 litres it's not worth the coin...
  • ralphski
    ralphski
    HAVE WE FINALLY GOT THE ROD ON THE ROAD TONY ?????????
    Look forward to seeing it on the Poker Run...
  • VRodBob
    VRodBob
    5 years ago
    Quoting webcke1 on 27 Nov 2011 08:12 AM
    Hi,
    Hope you can help. I have 2006 VRSCSE2 and want to convert its tank to a bigger one. I have checked the ultimate engineering website and it is still available. What's your experience so far? Did you install it yourself and did you buy the lockring tool to help you with the install?
    Bob
  • drod
    drod
    5 years ago
    https://www.fredy.ee/v-rod-5-gallon-tank/
    Fitted one of these tanks last year. Slightly smaller than the Unlimited Engineering tanks but also less fucking around. I get 250kms to a tank full, would probably get more if i tuned bike, plugs and pipes still run black, (one day)..
    took tank out and used rubber strap oil filter tool to remove cap, That was before he offered special tool.
    Ordered tank, paid using paypal, tank was delivered in 7 days from Estonia during covid lockdown.....got any queries just ask.
