Online: GeoffP, John.R
S & S Question
  • Outlaw01
    Outlaw01
    Markings are usually on side of the carby
  • Outlaw01
    Outlaw01
    Get a pic up of the carb
    all S&S have marking's on them too I.D.  look with a torch, ? a stock early carb fom 1972 to 1987 will fit on & S&S inlet manifold anyway's also
     that is a flowmaster carb . Screaming  use them in the early day of there didn't even have a cattledog back then , about 1985 they were renamed under the screaming eagle brand also screaming 1st carb.  the flowmaster is a good carb but a little bit hard too jet  becausepeople do not know them , i still have  a couple of friend's with them on there bik's but you don't see themm anymore , they are a 46 m.m.  butterfly carb with & acc pump  & come with a K&N air cleaner element for stock harley cover ,  not S&S  that for sure   ,  if you need a had too dial her in i could help.                         your's is & late 80's EVBT 80 c.i. ? ,    you would have to  check timing & clean fuel tank 1st before you start on the carb ,
    they were made by Keihin  sold under Flowmaster  brand 1st,    & then harley  Screaming Eagle  hope this helps ,  they are a good carb
