Online: GeoffP, Hilly, speedzter
Not returning to idle
  • Cruisin
    Cruisin
    I can remember someone posting about this before but cant find post.
    Here goes anyway. 48 not returning to idle (worse with some fuel more than others).
    Anybody with ideas would be appreciated (or a better memory)
  • Deadwood
    Deadwood
    Have you fitted new bars recently?
  • Sprocket
    Sprocket
    Do you give the throttle a rev as you turn the engeine off? If so it will idle higher next time you turn it on (efi sportie models)
  • Cruisin
    Cruisin
    No new bars or rev when i turn off. Im pretty sure that it is the same issue that i can remember
    someone else having & they fixed it by removing & cleaning a jet or valve of some sort located around
    air intake.Memory not much good (treated brain like an amusement park for too long)
  • TC883
    TC883
    Could be the throttle friction screw. It sits under the throttle, and can get sticky, stopping the bike from returning to idle. Try backing it off half a turn. Also try a light squirt of silicon lube on the throttle assembly. Try the simple things first...TC
  • Cruisin
    Cruisin
    Yeah checked all that out,cable is loose at throttle body when in return position.Also it only seems to do it when engine is
    warm-hot on a cold start its fine.
     the bike sounds lean  esp down low
  • Cruisin
    Cruisin
    Maybe i should pull a plug & have a look?
  • Cruisin
    Cruisin
    Just checked plugs. Grey on electrode nice n dark around circle bit.(lol)Looks like running good overall but cant really say if lean at idle.Seems to be intermittant for example today was fine. Thinking maybe a bit lean because today very humid therefore air would be thicker?????
  • Sprocket
    Sprocket
    What tuner are you running?
  • Cruisin
    Cruisin
    Didnt buy tuner because i would only fiddle with it all the time,but was tuned with screamin eagle from new when pipes & intake installed. Just checked altitude where i am (290m) above sea level & bike was tuned at fairymeadow which is more or less at sea level,so maybe thats the problem,also weather starting to warm up so problem more pronounced.(???????)
    Sounds like a ECU Problem if you say the Cables are OK,
  • Cruisin
    Cruisin
    Thanx for ya help fellas, sounds like i might have to get looked at by the new generation bike
    mechanic/computer guy.
  • Rocky2010
    Rocky2010
    Could be the IAC motor on the throttle body.
    You did say that you have a 48 correct me if I am wrong but your bike should still be under warranty, take it back to the stealer.
  • Cruisin
    Cruisin
    yeah 48 still under warranty but they were the ones that tuned it in the first place.
    Have heard good things about a local bloke round here so might check him out(dont mind paying if jobs done right)
  • 666
    666
     yep probably iac control motor just did one on my iron so far fixed the prob but you should be able to get it under warranty $66 part good luck
  • 666
    666
     check out workshop general page 10" dyna eratic idle" ps on friday there was only 4 left in oz ???????
  • Grand Tourer
    Grand Tourer
    same thing with my cooks nightster - replaced the IAC Motor as it was worn, idles back down the way it should now. Mine's next!
  • Sprocket
    Sprocket
    What is an IAC motor?
  • Grand Tourer
    Grand Tourer
    Bit of an explanation below..........our mechanic told us when using high flow aircleaners they can get worn and a simple fix is to replace them (not sure if this is correct but worked okay)
     IAC - Idle Air Control - An electric valve that's threaded, one turn of the valve is called a "step." It's controlled by output signals from the ECM to open and close as needed to allow enough air into the engine for starting and idle operation. (Throttle closed) The more steps, the greater the amount of air enters the engine through the IAC passages. It's that ugly looking black thing you can see just inside and over the top of the air cleaner.
