TC88 Cam Chain Tensioner & cam upgrade suggestion...
  • Deadwood
    Deadwood
    Got another question as my knowledge in regards to engine internals is non existant.
    Wih my bike about to click over 100,000 k's and the previous owner known to not really look after it, I have heard the cam chain tensioners can be an issue? I don't kow if the previous owner had them replaced or whatever I'll get someone to look at them but I'm thinking that if they do need replacing I could get a cam installed just to give the bike a bit more pep.
    Don't need anything over the top as the 88 goes pretty good, just a slight increase in low end and mid range if that's acheiveable?
    Any suggestions? Bike is a 2000 Dyna.
    I take it you dont want to touch the top end at all ?
    If the bikes got 100k on it, I would definately go to the newer style Hydraulic tensioners, which mean's a new Cam plate and oil pump.
    Then you need the "Conversion" Cams to suit.
    If your pretty happy with the power, but want a little more , maybe look at Andrews Tw26.
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    while you got the cover off to sort the tensioners get the mech to check runnout on the pinion shaft an also get him to check the internals of ya oil pump
  • WAGlide
    WAGlide
    Just go a 00 Wg done with the new -11 hyd tensioner kit. No mor cam position sensor either. Got back from a 2600km ride and all is good.
  • Deadwood
    Deadwood
    G'day guys, thought I'd wait to respond hoping for some more suggestions but the info is great.
    Humongus, that's what I'm looking for I guess, if you don't mind what did something like that set you back parts wise?
  • Aunty X
    Aunty X
    I've got what Wozza's got on my bike DW. Will be at GC soon, you can take my bike for a ride and see what you think first hand.
  • Choco
    Choco
    Just got a quote today from the Harley dealership to supply and fit the new SE hyd tensioner to my 2001 Super Glide the price came to $1378 now is this good or bad, but it's got to be cheaper than a motor rebuild if the old system fails cheers.
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    got a real good deal goin atm if you can pull motor ill set it up with a heap good gear an itll be reliable and have plenty horses when ya need it ..i can trim the price a bit too an do only the bits ya want or need
    http://www.hdforums.com.au/Default.aspx?tabid=71&forumid=10&postid=388749&view=topic
  • Deadwood
    Deadwood
    Very nice price Ol Skool.
    What would you charge to fit hyd tensioners, oil pump, cams etc as per our posts above? Just a rough ball park figure on labour...
    I would love to learn this stuff myself but am shitscared ill fuck something up even though I can follow instructions pretty well, nice if there was a worksnhop where you could learn as you go with someone showing you the correct way, someone had that idea floating around here i think.
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    bout 250 maybe bit cheaper if you supply the parts but really why put tensioners in ..only gotta worry bout em in the future id put gear drives an cams oil pump(i got hi flow billet one here ya can have for 250 brand new ) inner an outter cam bearings and adjustable pushrods an hl2t in ya lifters .for 450 id port n polish ya heads if i doin the rest of the work thatll give ya heaps better responsiveness an still be ok round town but also be good on hwy with the heads breathing better too
  • Deadwood
    Deadwood
    Thanks mate, best I talk to the treasurer and see where I'm at financially. Appreciate the advice.
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    pm ya number ill call ya morrow if you want i got unlimited on moby so can save others gettin big bills
    theres a few different ways to go once i get a better idea of wat ya ride like an wat you want also (not being rude or nosey) how mich you want to spend can work out few diff prices for you
  • Choco
    Choco
    I was looking at going to gear driven cams but what is this crank shaft run out I read about, some are saying if the run out is to much you can't fit the gear drive cams is this right.
    Also the price of the gear drive cams I been told is about $950 then the oil pump should be beefed up as well another few hundred bucks I am just confused which way to go, maybe I should of bought another evo lol.
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    choco why dont ya come for ride up mate ya know me doors open or ill call ya morrow if ya want and explain it all so ya understand ..you gettin rain down your way fuckin dry as here mate ...ron in bundy
  • Deadwood
    Deadwood
    Well Ron I tried to get the treasurer to part with that stuff that grows on trees but got knocked on the head mate. In the process of moving interstate so not a good time anyway.
    Thanks everyone who helped for the advice, it will be done but in Melbourne instead of Queensland. Cheers.
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    doin chocos bike in next week or so if ya quik or if the ball n chain lets ya im doin oil pump lifters adjustable pushrods 26andrews cams an sn s gear drive an port n polish with labour fo 2k ride in ride out cheap as for chrissy
  • Deadwood
    Deadwood
    Crikey. I'll get back to ya.
    Another question, how long something like that take to do?
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    a week once ya drop bike in normally
    pm me an ill send yua my after hours number
  • Deadwood
    Deadwood
    Cheers Ozroder.
    Bit to think about when I get to Melb, also gotta find a good indy in the eastern burbs who can do all this for me.
