Online: tussuck, blueystar
Rough running evo
  • Bourkie
    Bourkie
    Hi Guys I have an 85 EVO running rough with a bit of popping at idle, I have cleaned the carb and set the float at 16.5 mm the compresion is 125 psi instead of the 90 psi listed in the book should I  be using biger jets to get the it to idle?
    when I got the bike it had 14.5 mm float and fouling plugs because of the rich mixture
  • Bourkie
    Bourkie
    Hi Dave it is the FLHTCL no baffles with std mufflers 125 psi on both pots, clean fuel, clean  new plugs,  I have just driled out the cap on the mixture screw but cant start it till my son gets up at 330pm as he works nights mine drilling
    Cheers,
    Peter
  • Bourkie
    Bourkie
    stock carb
  • Bourkie
    Bourkie
    Thanks dave,
    at the moment the bwhen hot the idle stays at 1000 rpm for about 40 seconds then drops to 450, will let you know how it goes later on
    love that andrews catalog! will be ordering the pump upgrade ASAP
     that model has shit inlet manifold set-up if it;s still stock they were a 3 peice set-up called complyance, if it still has that replace  with a S&S of a B carb as these fit straight up  bolt pattern etc, or if it has the later manifold  replace the inlet rubber seals to the cly head to inlet manifold if  there over 5-6 yrs old they will be stuffed & leaking air,    can run good cold & then stuff-up when hot as the EVO grows with heat expansion up to           2 m.m. from hot to cold  when hot they leak .  test flood spray some WD40 @ the seal when hot  with the motor running & the  idle rev's will rise
  • Bourkie
    Bourkie
    I tested for leaks with LPG and had no change so it may have had new rubbers before I got it,
  • Bourkie
    Bourkie
    Thanks guys for the help, she is running just so nice just ticking over at 1000 RPM and so responsive any idea on who to see for the ramjet manifold
    Cheers,
     if it's running the stock early 3 piece manifold  get rid of of it , even if it have the later type still put  2 new seal's  in against the cyl head then you have a starting point,    it will cost about  8 buck's + & 1hr's work
  • Bourkie
    Bourkie
    thanks mate will do
  • LamoInsano
    LamoInsano
    Anyone know where to get CV carb mod kits in Aus? For a 92 DynaGlide Custom
