Sissy bar for 08 Superglide.
  • Galloway
    Galloway
    Want to get a short sissy bar for my 08 Superglide. Anyone got any ideas?.
    I'm thinking.. Bolt on that I can strap luggage to and also more comfortable for the missus.
    Got a superglide custom seat fitted. Not much use for passangers,  so need somthing to give them a bit more support..
    Whats good and how much should I expect to pay?
    Thanks in advance...
    JG
    My lad is slipping off the back , 2012 fxdc , looking for same low bar with rack that,s detachable .
    I have the accessories book , what part no.s did you use ?
    Thanks for the part #s , ordered the same except backrest pad , that,s 51641-06 . Will order rack at later date , need to save up ! $425 for the bar , pad , detach mounts , fitting kit and turn signal mounting points (different stalks for rack to click on ) , Cheers , Tim.
  • Train
    Train
    Galloway, I saw a sissy bar a while back. Think it was from kurkyn. It uses the seat bolt to hook up
    Looks taller than catologue picture . Pictures show medium low shorter than low . Going tomorrow ?
    Hey Scouser got all my bits today . Have to change back pad , it doesn,t fit the bar . How did you go with the wiring ?
  • jcsport
    jcsport
    Mine was on it when I bought the bike, genuine Harley bits, mid height. The dealer gave me a breakdown on the costs of the extra bits for the bike and this came in at around the $500 mark so Scouser the price of yours is right. They are great for 2 up riding - the missus loves it and it it's on and off in seconds. The bonus is that my Ventura 53 litre bag slips over the backrest and sits on on the rack so it's great for weekends away but do need some saddle bags as well though, the amount of crap women take away with them...
