Online: Stuart
HELP!
  • Deadwood
    Deadwood
    It used to be that you would have to choose 'edit' and when it takes you to the edit screen there is an option to delete next to the 'submit' button at the bottom. Maybe try that.
  • Ross
    Ross
    Hey Halfsleeve, don't knock the poor PEBCAKs. Next you'll be spouting RTFS, although if I YELL this loud enough, it usually works with my PEBCAKs!!
  • Ross
    Ross
    PEBKAC = Problem Exists Between Keyboard And Chair
    RTFS = Read The Fucking Screen
    If you sort out these problems, I reckon at least 80% of IT issues are sorted, where I work anyway. Not that says much...
