New Softail
  • Draino
    Draino
     I live in the Pilbara and I'm going to get a Softail std or black line from one of the Perth dealers. Do you know if I can fit pipes, tuner and intake on a brand new bike and ride home? Because I won't be back in Perth for months so I can't clock up the 500 or so k's then have them fitted.
  • Draino
    Draino
     I ask this because I've been told you need to clock up your first 1000 then get it done but it's 1000 just to get home and I'm not riding home then turning around and going back, I can't see why I can't do it before I pick it up
  • Draino
    Draino
     Sounds good and frasers was the store I enquired at so I will go and see Perth hd
  • Draino
    Draino
     Not bad if the black line had the fat back tyre and the speedo on the tank I would go it I want to change bars but the ones I want look like they will make seeing the speedo hard
  • Burraburra
    Burraburra
    Wont help you here Draino as I am on the East Coast.
    However, picked my ride up brand new Dec 09 from Blacktown HD.
    Got fitted V & H side shots plus SERT with air cleaner etc before I picked her up.
