1984 FXWG Shovelhead
  • RudeBoy
    RudeBoy
    Hi guys, ive spotted a 1984 FXWG Shovelhead (belt final drive) for sale. Is there anything about these very last shovelheads I should know about or be cautious about?
    cheers for the advice!
  • clarkie
    clarkie
    good old motors, i have one and if you look after them they are ok,just dont expect to run with the newer stuff,but with right cam,carb etc they go quiet well,good luck
  • The Don
    The Don
    G'day guys,
    83-84 FXWG 4 speed belt drive, some 84's are Shovels, Evo motors were used when the Shovel motors ran out.
    Great bikes, in both Shovel and Evo form ( As Kiwidave said, Buyer Beware. It all depends on the previous owners)
    Are you mechanically minded Rudeboy? If not take someone with a bit of savvy to look at the bike.
    And as requested by Dave, post some pics.
    Cheers,
    Cris
  • RudeBoy
    RudeBoy
    the bike is on bikesales.com, here it is CB104421
    the owner has confirmed its an 84, not a 1986 (not sure why its advertised as a later model)
    but ive been told its never had Aus registration, it only has import papers. which means i need to get it egineered first, such as the speedo, lights, mirros & exhaust (for emissions, is that correct?)
    even thought its a bit of a treck, sydney is a closer place for me to look for a bike. 2  80's model shovels have popped up on ebay today (a fxe super glide & a sturgis) I've sent the 2 a msg hoping I can see each bike on the same day!
     hi,  the best model shovel made 1984 has evo style forged narrow flywheels & droped forged con rods with german made pistons stock, pistons would or could be replaced buy now  with aftermarket brands ?, the rear  4spd trans drive pulley sits on a weak spline centre & wear's out          (  i think andrews make 1 ,  the nut is thin & cums loose   you  can replace it with the later thicker nut
  • RudeBoy
    RudeBoy
    thanks everyone, you've given me something to think about and some points to raise if i have the chance to fly out & see the 84 FXWG. If not Ill have a few more things to look out for if a journey down to Sydney to check out some bikes.
    Im planning to work on the bike and bob it out. similar to this one, but in my own sort of way
    http://www.flickr.com/photos/speedkingphoto/3995538012/sizes/z/in/photostream/
  • panhead_pete
    panhead_pete
    Did you buy it?
