Engineer in Sydney
  • oldmate
    oldmate
    Just about to embark on a frame up build.
    Would like to know about engineers in the Sydney area who would be good to do the report required to get it registered.
    I am just about to get the frame built and wanted to make sure i am on the same page as the engineer from the beginning as i am sure it will differ from state to state.
    Any advice appreciated and i hope to do a build thread which may help anyone else looking to do the same thing.
  • Frank7214
    Frank7214
    All current engineers for NSW are listed on the RTA website.
  • Frank7214
    Frank7214
    Try Peter Smith 14 Little st Camden (02) 4655 9440
    Current as of 22nd September 2011
  • oldmate
    oldmate
    Thanks guys,
    I am getting some mixed opinions on this one.
    Are you supposed to get pre approval before you start a build?
  • Frank7214
    Frank7214
    If you intend to build a custom vehicle, I suggest that while you mok up the vehicle, talk to an engineer and a Blue Slip person to confirm what is required to complete your project and comply with the regualtions.
  • wayne.craft
    wayne.craft
    Oldmate you might want to duck down the local RTA and grab
    the forms and fill out, Lodge and wait for a reply...
    They will tell you what needs to be CHANGED from your plan
    and ease your way with engineer and rego.
