Online: Stuart
Alarm going off when I turn the key?
  • kingchops
    kingchops
    Washed my bike today then went to go for a ride and what do you know, I turn the key and nothing but the figgin alam goes off.
    Wheeled the bike back into the garage with the bloody alarm going off,  tried a couple more times to turn on the ignition with bike on stand and nothing but the bloody alarm.
    Has anyone experienced this?
  • sophtayl
    sophtayl
    Hey KC,
    check the battery in your FOB. had this happen......coincidence maybe that it occurred when you were washing yourbike, but the battery in the FOB may have gone flat.
    M
  • kingchops
    kingchops
    RT,
    Scotty - yeah, would seem like that's the case.
    RT - Just did that, I was sure to keep water away from the electricals, but just gave them a drying just in case.
    Mick - thought the same thing and I tried both fobs, but the same problem.
    I noticed that the red flashing light that's normally on when the alarm is armed is not on now, and I can't seem to disarm the bloody thing.
  • nobody
    nobody
    Try disconnecting the battery and reconnecting.Could also be caused if the battery in the biked has gone open circuit or had an internal short circuit,what is the voltage at the battery,and what does it drop down to if you put the lights on?
    nobody
  • twincam88b
    twincam88b
    Bloody electronics
  • sophtayl
    sophtayl
    how cold is it at the moment KC? have you had a cold snap?
    M
  • Curly's Lowrider
    Curly's Lowrider
    Had a similar problem with my bike a couple of years ago. Was just getting harder to start. Bought a battery tender I think it's called. Checked and tightened the terminals, fitted the leads for the battery tender and haven't looked back. The battery is the original one from new. Now going onto 9 years old.
    Now that I've said that It'll let me down tomorrow.
  • WhatTaxi
    WhatTaxi
    on me dyna , after a wash the neutral light flicker's on and off for about a day or two
  • sportytrace
    sportytrace
    Hey Kingchops, Check your relays maybe...
    TT322 – July 26, 2007 - 2007 XL Models with Discharged Batteries or Very Low Voltage 2007 XL Models with Discharged Batteries or Very Low Voltage
    Harley-Davidson has found some ’07 Sportsters where the batteries are going dead after a night of sitting. The root cause is water intrusion. Water can run down the harness, funnel into the fuse block area, and then bridge the system relay contacts. The system relay has constant power available on the 30 terminal.
    When the system relay is activated, power goes to the ECM, and then the ECM sends power out to the IAC. The IAC will then run until the battery is fully discharged.
    To prevent this issue, Electrical Contact Lubricant (p/n 99861-02) can be placed on the terminals and base of the system relay, and the receptacles at the fuse block. This will create a water barrier once the relay is installed into the fuse
    block.
    Motorcycles exhibiting this condition could also have corrosion present, and if necessary, should have the relay terminals and receptacles cleaned with a wire brush or replaced.
  • rkc07
    rkc07
    see Lube does fix things lol
    and to think women give us men a hard time when we suggest getting the lube out
    now we can say a woman has suggested lube fixes the issue ..thanks sportytrace
    ps ... lets not get bogged down in specifics here ..just enough to say "lube" not electrical lube
  • kingchops
    kingchops
    nobody / mick,
    Yes there has been a fairly consisten cold snap over the last couple of weeks, that can't help matters. I've got a battery tender on the way I'll give that a go for a couple of weeks if it does't come good I'll go get a new battery.
  • sophtayl
    sophtayl
    car battery let me down that way the other day KC.
    soundslikea known prob though so good to fixat same time..
    Mick
  • nobody
    nobody
    I was going to mention that Scotty,but some probably wouldn't realise what they were hearing,and quite often when you get off the bike after a ride,all you can hear is the metal breaking and crackling as it starts to cool down
    nobody
  • nobody
    nobody
    Had the problem happen to me today.Checked battery voltage and it was fine,headlights were bright with ignition on,put battery charger on battery and it didn't make any difference also connected jumper leads off the car to battery,still no difference.So I decided to look what could have caused the problem,as I had just been out all morning on the bike with no sign of any problem.1st thing I noticed was I had my phone in the same pocket that I had my fob for bike,I never used the phone and it never rang,BUT phone still emits  a magnetic field.I also noticed thet I had the fob for the car in the same pocket,as I had just moved the car so that I could put my bike away.Went inside and grabbed the spare fob and tried again,the bloody alarm still went off,tried a few more time with the same results.Then bingo,it went back to normal,turned off bike and tried with the original fob and it worked ok as well.I am thinking that having either a mobile phone or another Key fob from another vehicle in close proximity to the Harley fob is somehow confusing the system on the bike.
    nobody
  • sportytrace
    sportytrace
    Hey KC, Any further battery issues? Have you resolved the issue?
    Trace
  • Cush. Os
    Cush. Os
    5 years ago
    Had this problem with my fat boy, as soon as I turned the bike on the alarm would start, tried everything with no joy.
    Eventually turned to the fob, replaced battery still going off
    After a while I noticed there's a little prong inside the fob that was facing the wrong direction.
    Flatened it out put it back together and no problems. Things like this usually are a fob issue apparently
    5 years ago
    Fob Battery...
