Speedo Recalibration
  • Clement
    Clement
    Hi, has anyone had to do a speedo recalibration? Do you think it is necessary if i go from a 16' rear to an 18' and 19' front to a 21'? My ride is a 2011 Iron sporty.
    Be great to get your feedback.
  • AJ56
    AJ56
    yep, you will need the recalibration..
  • grim
    grim
    Hey clement reckon youll have to if you need to know acurately how fast you are going. I swapped out my transmission pulley on my 07 kingy as I didnt like riding around in 5th gear most of the time. I got a recalibater from "dakota digital" that plugs into your gearbox and into your speedo leads. It has a couple of arrows on it so you can adjust the speedo up or down, once you have that right it remembers the setting. Very accurate---cheers Grim
