Online: GGUser754
V&H Throttlepak
  • conmore
    conmore
    Hi there
    I recently bought an 09 Ultra Classic Glide which has throttle by wire. In comparison to my Fatboy which has conventional throttle cables I'm noticing a slight lag in throttle response particularly off idle.
    I've got a SERT with the bike but was wondering what other forum users reckon. Re-map and tuning will take care of it? Or fit the Vance and Hines Throttllepak which states it removes the lag?
  • HogBag
    HogBag
    Conmore
    What race tuner do you have on the bike as there's two Does the bike have a stage one kit. Mufflers and hiflow aircleaner ?
  • conmore
    conmore
     Hi there
    Bikes' stock 96ci, got a SERT and hi-flow air filter with V & H Monster Ovals fitted.
  • conmore
    conmore
     To the top :)
  • HogBag
    HogBag
    From memory Harley has a update they can load with the DT that helps that hesitation on the 09 baggers.
  • Steve Cole
    Steve Cole
    SERT was not made for a 2009 so you must have the SESPT unit with the button on the interface box. The SERT was made by TTS and sold through HD and the last model year supported was 2008.
  • HogBag
    HogBag
    If you have the race type super tuner you can adjust the throttle plate lag time with it.
