Fat Boy Bars
  • Moriniman
    Moriniman
     Hi,
    I have 2010 Fat Boy Lo that I've fitted with a nacelle.
    I'm looking to change bars for something like beach bars or maybe small westerns but not sure of tank clearence at lock.
    Anybody with something similar or recommend some bars that may suit but wont alter the light too much??
  • jungle
    jungle
    year man i,ve got burlie mid westerns  black on my lo , i recken they,re the ducks nuts
  • Isaac
    Isaac
    How's about riding the bike to a Dealer and borrowing a few bar styles to see what fits? 'Burleigh Bars' suggested I drop in with my bike for a similar reason.
  • Mac_lo
    Mac_lo
    jungle could you throw up a pic of your lo with those bars? thinking about it for mine.
  • fathee01
    fathee01
    I have western bars on my fatty, tank clearance is not a problem.The nacelle is not a problem either, pick the bars you like and if for some strange reason you encounter clearance problems a set of risers will fix it .good luck.
  • jungle
    jungle
    hey humongus,can you tell me we,re you got the risers for your burleigh bars, and any chance of a pic , cheers jungle
  • jungle
    jungle
    thanks humongus pm sent
