Online: obisteve
Annihilator brake pads
  • The Don
    The Don
    G'day Dazza,
    If you've got the four piston version it is the same as a PM four piston 125X4R, Annihilator copied it.
    A mate gave me a caliper for the front left, and after a bit of research I rebuilt it using a PM kit.
    Got the rebuild kit off Rollie's and they also keep the pads.
    Rebuild kit was about $12 and the pads $45.+ postage.
    Cheers,
    Cris.
  • The Don
    The Don
     Yes Dazza,
    PM part# 0052-1602DS  Brake Pads (Pair)
    PM part# 0052-3002 Rebuild Kit.
    Cheers,
    Cris.
  • The Don
    The Don
    Haven't had the chance to change over to it yet, but should fit as a glove, my mate has a 92 softail custom and he gave me the bracket as well. He changed his to DNA 4 piston front and rear.
    Cheers ,
    Cris.
     i think i have a set or so, there is a slight differance in the PM pad  to other brand 4 spot, i think i have Goodridge brand
    yes , thats all i do is work on harleys 6 days a week & every now & then 1 a mth i take a day off & take 1 to the race track & put the elbow to the ground
