S100 . .where the hell can I get it ?
  • LewisFXR
    LewisFXR
    I live on the far Nth coast NSW . .does anyone know where the hell  I can get a can or spray bottle of  S100 total cycle cleaner ,  locally  ?
  • FatboyMick
    FatboyMick
    I thought North Coast V-Twins in Coffs have that shtuff, i could be wrong, often am. But give them fellas a ring
  • spanners
    spanners
    If they havent they should be able to get it I seem to remeber it is in the H-D big parts book in 1/2, 1 and I think 5 litre pack??????
  • HogBag
    HogBag
    North coast vtwins at Coffs has it. Seaside Balina should have it also.
  • Rocky2010
    Rocky2010
    Frasers in Concord sell it, may have it in Newcastle store also.
    Not much good on bare alloy
  • evilsim
    evilsim
    Washed mine with S100 today it's good stuff.
  • Conga
    Conga
     Any HD dealer should be able to get it. I just used some on my engine and i reckon it's the best thing since sliced bread. I tried ordering it over the net but was informed it was unable to be posted??? 12 bucks a can i ended up paying and used it all in one go. Well worth it.
  • Lee HD
    Lee HD
    S100 cycle cleaner is a good product and can be purchased or ordered from any HD dealer but you have to be very careful using the cycle cleaner make sure you use it to the directions completley and make sure you absaloutly rinse it all off even when you think you have rinsed enough rinse again otherwise it can leave some terrible White stains that can't be shifted as a mate of mine found out on his deuce all the other s100 products I use every single one of them and they are great I highly reccomend them but as for washing your bike I would get yourself ct18 superwash from supercheap you can buy it in 1litre or 5litre or 20litres which I buy for $90 and lasts for ever with the ct18 it's simple and you don't have to worry about anything like you do with the s100
    just grab yourself a a few 1litre spray bottles I put 100ml ct18 in it then fill the rest up with water and spray it all over your bike I let it sit for about 45 minutes to a hour the longer it sits the better job it does then with ya hose with a nozzle attatched just spray it all off and then I just use my air force blaster to dry the bike simple and no need to touch the bike and risk of scratches the ct18 will strip any wax on your tins but then again so will the s100 I wash my bike once a week using this method followed buy using the s100 detail wax on the tins and once a month I use the s100 carranuba wax try it you will like it and it saves you having to worry about if the s100 is completely rinsed off
