installing chrome switches
  • route 66 tours
    route 66 tours
    G'day Guys,
    On my recent route 66 tour i bought a set of chrome switches for my Deuce. I put them on over the weekend and when i went to start the bike, the accessories fuse had blown. I thought that was pretty weird as you dont have to remove any wires or even disconnect any wires to change them.
    Have any of you guys changed your switches and found the same problem??
    Cheers,
    Dan.
  • route 66 tours
    route 66 tours
    hi robo,
    ill have to have a proper look again when i get home, i couldnt see any obvious pinches or kinks in the wires, but ya never know!
    Cheers,
    Dan.
  • HWG
    HWG
    Yeah did the same myself, as Robo says, check again!
  • softyJ
    softyJ
    I had changed mine and all sweet. The wires are in a tight spot so get it apart and check the wiring
  • route 66 tours
    route 66 tours
    i checked the wiring and all seems good. i replaced the fuse and it hasnt blown again.
    anything else i should do?
    if the fuse hasnt blown again after checking the wires, am i right to assume it will be o.k.?
    Thanks for your reply's
    Cheers,
    Dan.
  • rumman
    rumman
     mine kept blowing headlight fuses ,and after pulling all the lights apart and checking for bad earths or shorts i still couldnt find my problem. my next step was to pull the switch block apart then cut open the heatshrink and check each wire. while there was no marks or holes in the heatshrink there were two wires in side that had sqaushed and split and were contacting each other, taped them up and bobs your uncle all good !
