Screamin Eagle Deuce
  • deuce2004
    deuce2004
     Hi
    i have a 2004 screamin eagle 100th anniversary deuce
    my bike is fuel injected and has the factory exhaust fitted
    my pipes have no 02 sensor is this normal
    i am about to order a set of new pipes and want to order the right ones
    under my seat the ecu has delco as the brand which i would have thought was factory fitted
    any help with this appreciated
    Craig
  • HogBag
    HogBag
    Craig
    Harley"s didn't have 02 sensors in the pipes untill 2007.
  • Rooster
    Rooster
    Get any exhaust to fit your model bike.
    If yer new exhaust has O2 ports fitted you can just screw in bungs to plug them.
    Are you sure your ECU doesn't say "delphi". Don't know what sort of map the SE models run in the ECU, but you may need to add a tuner to yer shopping list as well.
    See TTS vs SEPST thread in here for more info.
  • deuce2004
    deuce2004
    Cool
    thanks for the quick replies
    just wanted to make sure before ordering my pipes
    Craig
  • HogBag
    HogBag
    Getting the 02 sensors in the pipes is a good idea because your 04 bike can run closed loop tuning. If you decide to do engine mods you can run any of the latest tuners TTS Thundermax PCTV PCV SEPST but if your happy with the stock bike still consider a tuner to help keep the engine temps down with a richer running engine. If you decide to stay open loop with no 02 sensors you will get the best results having the bike dyno'd. The dyno operator would give you the best advice on what tuner he prefers to use.
    Good luck
    HB
  • deuce2004
    deuce2004
     Thanks for the reply mate
    My bike was imported from the USA ( California )
    Will most likely fit a set of Vance and Hines big radius pipes and fit bungs where the o2 sensor holes are
    Craig
    0
  • simmac18
    simmac18
    Mate you should have a look at the Vance and Hines Big Radius for sale in the For Sale section they are good buying I was looking at them nothing major wrong with them that you can see in his photos
  • deuce2004
    deuce2004
    Hiya mate
    The bike shop that i purchased my bike from has done me a great deal on these pipes to supply and fit
    Booked in for Saturday morning
    Craig
  • deuce2004
    deuce2004
    Had the Vance and Hines big radius system fitted today
    The bike shop had to fabricate a mounting bracket and did an awesome job
    The sound is something else and the bike is reving a lot better
    Craig
