Online: GeoffP, rushkartech
Andrews N4 CAMS
  • Clement
    Clement
     Does anyone know the difference between these 2 N4 CAMS they appear to be the same, the product code is the same but not sure which one i need to choose...anyu help would be much appreciated..
    "N4 CAM .490"" LIFT"
    Part No.: 494751
    Manufacturer Part No: 298150
    Manufacturer: Andrews Products
    ANDREWS N4 CAM 00-11 XL
    Part No.: DS199076
    Manufacturer: ANDREWS
    Cheers,
    Clem
  • BURTO
    BURTO
     Same manufacturers numbers.........same cams.
    Just different suppliers numbers.
    Mark would charge the same for either I'm sure, email him and ask if you are worried.
    Burto.
    early & later N2  andrews cams ,  1991 cam's can just change the drive gear  on #2 cam  to fit 00 & up  just buy the right year model fitment , what year model sporty ?
