Online: GGUser744
Bitter end old school choppers
  • Bunyip
    Bunyip
     Gday boys,
    Has anyone bought a conversion kit from these guys? Ive been tossing up between getting a roller going, and found these conversion kits. They look sensational, and are priced really well. www.bitterendchoppers.com/
    Any thoughts???? Im wondering if I would get stung for import tax?
    Cheers guys.
  • darkdesign
    darkdesign
    check xlforums, I'm not sure if you would like the results. If memory serves correct, not all of the frames are that straight. But if you're ok with that, the prices can't be beat.
  • darkdesign
    darkdesign
    just had a look myself, can't find the one my brain thinks its remembering. Forget everything i said.
  • Mr.Mow
    Mr.Mow
    Do a search of chop cult, if anyone has the low down on bitter ends quality it will be those guys.
  • darkdesign
    darkdesign
    http://www.chopcult.com/forum/showthread.php?t=10887
    found it. There's other threads where stuff was fine. But not this guys, apparently. And with us being so far away, if there is dramas, it'll be a right pain in the arse to get sorted.
    If it just a Ridged Rear Section call Luke at Gworks, He builds his own 03 5277 9296 http://www.gworkscustomcycles.com.au/
  • Bunyip
    Bunyip
     Thanks Walka,
    Will do. Have read a few good reviews of these blokes. Would rather keep cash local if its poss. Looks like a decnt kit though.
  • Shedrat75
    Shedrat75
    I got this kit and doing the frame was a piece of cake just add extra guesses at the lower part of the frame and some where it joins at the backbone. Also get some solid slugs made too hammer into the frame as it just comes with two smaller bits of pipe too weld too.I will add some pics of mine once everything is spot welded and I strip it for final welding and smoothing of the frame before powdercoat
  • Bunyip
    Bunyip
     Genius, will be keen as hell to see it, thanks mate.
