2011 Fat boy Saddle bags
  • Henry
    Henry
    Hi Guys
    Just wondering if anyone has the HD  detachable saddlebags for a fat boy, exhaust is the V&H big radius. the GLW and I are touring Tassie over christmas, and I like the idea of having the hardware there and having them removable when not needed when we get back. The price scared me a bit $1200.00 (will look after better when ordering so this must be the rec retail) for the saddle bags, attachement hardware, and indicator relocation hardware, I was going to fit them myself,  but saying that they appear to look ok from the pictures I have seen.
    Does anyone use an alternative? or other brand/manufactures that work as well?
  • SoftailSteve
    SoftailSteve
    you can look at www.realhog.com for saddle bags there are alot out there
  • Fatboy80
    Fatboy80
    Hi Henry
    I fitted the HD quick release saddle bags to my 09 Fatboy with rienhart cross back exhaust and footboards, in the catalouge it say they wont fir with the rear foot boards but they do the HD ones are a bit expensive but are extremley good quality, they should fit fine with the V&H pipes got the bags for just under $1000 already had the indicator relocation kit and the double mount for the bags and sissy bar on the bike when i got it, shop around and push for a good price if getting the whole lot we got HOG group discount which helped
  • SoftailSteve
    SoftailSteve
    about to buy a screen and other bits from m&m and looking at there web page there is a good selection to look at when i got my heritage bags i got them from a hd dealer in tamworth bikes and bits very good to deal with
  • Henry
    Henry
    Thanks guys
    I have ordered the detachable bags, back rest, hardware and indicator relocation kits, I did look at the non genuine stuff but when you add in all of the gear the prices are not that different.
