Rocker / C = CVO Springer
  • HD68
    HD68
    Hi all. Has anyone noticed that the Springer CVO looks alot like the now discontinued Rocker. Right down to the 240 rear and finned oil tank. If it is it would also add some Accessories to the rocker stable I would hope. Albiet under the Springer CVO title. In truth the Springer CVO rear end looks awesome I think.. Better than the Heartland . Just my opinion. Yeah Yeah The "Rocker" the "Gap" Blah blah . To each their own Yes?. This is AUSTRALIA !. Peace
  • Dan
    Dan
    Same frame for the most part but different neck, less rake to accommodate the springer front end
    The rear fender bolts straight on the rocker with the struts, seen a few done but dunno if the bobbed fender works on anything more than a 200 ass
    As far as it looking better than the heartland, well gotta disagree...
    ... But opinions are like arseholes, everyones's got one
  • HD68
    HD68
    Side by side they both look great. Great pics cheers Dan
  • wayne.craft
    wayne.craft
    so where is the springer guys ???
  • ductor
    ductor
    The Rocker was made of Duece parts
  • wayco
    wayco
    Just put a rocker/cvo finned oil tank in my deuce -be very careful what exhaust you use as the tank is bigger than stock & the bottom rear pipe nut is a bastard to get to-(i,ve got a vance & hines 2-1)-if u r pipes are standard type -now i understand why most rocker pipes have a separate listing
