Online: obisteve
TTS v SEPST
  • BURTO
    BURTO
     Lookin at trying the SEPST myself as the TTS won't work on the 2012 Dynas. Apparently I will be able to copy and paste all my TTS tables over.
    Burto.
  • BURTO
    BURTO
     Judging on the amount of time they have already spent on the '11 Softies, I don't hold a lot of hope for anything real soon.............Had to bight the bullet and go with the pro tuner, I will need at first a map for my 2-1 pipes, which I am having new 12mm o2 bungs installed this week.
    Then the heads and cams to follow in the next few weeks.
    Burto.
  • BURTO
    BURTO
     Doubt that I'll be doing much tuning with it for now Hilly...........just need a means to transfer an existing map to the bike. As long as it runs as good as before, which it should as it will be exactly the same build, then I will leave it at that.
    Never know what the future may hold though I spose!
    Burto.
  • HogBag
    HogBag
    If you fit the 02 sensors to the exhaust and plug the wires in you can run the SE supertuner or the TTS.
  • JD
    JD
    The Screamin' Eagle Pro Super Tuner Kit will provide the experienced race tuner with tools and data similar to what Screamin' Eagle uses to create its EFI calibrations for Stage Kit configurations. The system is designed for Harley-Davidson Electronic Sequential Port Fuel Injection, (ESPFI) systems offered on the following EFI-Equipped models (from here on referred to as the “current ESPFI” system):
    • 2001 – later Softail,
    • 2002 – later Touring,
    • 2004 – later Dyna,
    • 2002 – later V-Rod,
    • 2006 – Destroyer,
    • 2007 – later XL.
    ok for 2006
  • JD
    JD
    Hilly
    I am perfect
  • Yositime
    Yositime
    There are a lot of ways to tune a bike and get good results, and for the DIYer it is good enough. But for those contemplating the SESPT because they've heard its the best tuning device ever invented but want to make an informed decision, here is what some of the better tuning pros have to say about it:
    "After the ''Dumb Tune'' is finished and stored in the VCI and you go back to look at the stored map you will find the VE's along with the timing changed from what you set it. WTF. The DumbTune also tunes at 14.68 as a target, this has to be real good on your engine......when using this on a dyno you hold the throttle at the rpm and kpa area being tuned and count to 4, this is what Harley says to do, however if you ever did a V-Tune and watch the cell change from red to green you will see it takes at least 8 seconds to change....another duh...!!!
    Yes your right the TTS is much better and anyone that say you can get the same results with either tuner doesn't understand too much about these products..........the TTS is WAY better."
    "Just buy a tuning device that works as expected and doesn't take control of the tune so that work arounds do not need to be developed to end up with a decent running bike."
  • HogBag
    HogBag
    JD
    I don't bag any tuners but when people ask like this thread. TTS v SEPST what are we supose to do tell the guy to buy any of them because they work the same. Scouser ask a couple weeks back for the cheapest tuner I spent 1/2 hour searching on eBay for a SE cardridge to suit his bike because he wanted a cheap tune ? I didn't try and sell him a TTS I tried to help him out with a cheapest tune he could get for his bike I try to help people and if they ask what's the best tuner. Sorry I can't lie to them.
  • HogBag
    HogBag
    Scouser
    Great news on your SEPST. Don't worry about the dyno untill you fit those aftermarket cams your mates giving you.
