Online: GeoffP, rushkartech
Base Gasket or Seal on 98"
  • 2005 FLSTFI
    2005 FLSTFI
    I was looking at the gasket set I bought for my up & coming 98" build & noticed it had a base gasket instead of a seal.
    I have done a 95" build before & that had the base seal in it & had zero issues, so my question is which works better or they as good as one another.
    Thanks for any input in advance.
  • HogBag
    HogBag
    If your motor has Orings use them because base gaskets will raise the cylinders and your pistons will be lower down in the cylinder holes. Because the pistons will be lower in the cylinders this will give you a larger squish zone that may cause detonation issues with shit fuel . I have a couple spare cometic Orings if you need them send me a pm and there yours.
    PS what brand of gasket kit did you buy.
  • 2005 FLSTFI
    2005 FLSTFI
    HogBag
    The gasket kit is a cometic 4".
    PM sent also
  • HogBag
    HogBag
    Free
    PM your address or PO box and I will post them. Im at work and can't respond to PM on the IPhone
