upgrade an evo
  • Jinx
    Jinx
    Can anyone give me some advice on bombing up an evo. I've got the 42mm mikuni, V&H big shots,crane single fire ignition and a hypercharger already on it but I'm chasing a bit more grunt. I've also been looking at a Ultima El Bruto 113 cube motor to replace the evo. Any advice, good or bad would be great.
    Cheers Jinx.
     i would NOT  buy & el shito motor or a rev shit brand ,  maybe & S&S or can get the 80 c.i. happening with a bit of work  i have had 113.1 H.P, out of 1340 c.c. 80 c.i. in the 1990's , but i do have for sale a brand new short block 106c.i.  AXTELL Mountian motor EVBT  brand new everything        4 5/8'' S&S crank radius crack tested & shot peen conrods  re done & balanced  by pieter @ P&L Cycles , 40,000 ductile iron AXTELL  barrel's in 3 13/16" bore with JE piston's Delkron  heavy duty case's etc , 6K
  • Jinx
    Jinx
    Thanks for all the info so far fellas. I was looking at the S&S motors as well but they were a fair bit dearer. I haven't heard or read anything bad about the S&S though, so I  spose it all comes back to you " get what you pay for " Looks like there are plenty of other options out there as well to do the motor up so I'll keep checking things out.
    Jinx
  • wayne.craft
    wayne.craft
    Hey daddyracer56 do you know how to set up a mechanical injection on an Ironhead sporty '80 vintage ???
  • V2Evo96
    V2Evo96
    Jinx what are you lookingfor in terms of the build? For an EVO I would consider cams/carb/exhaust/ and a little headwork as in small compression bump to suit the cams and maybe a bit of cleaning up. You can put together a really sweet 80 c.i. motor for not a heap of $$$$ and have plenty of power-- and longevity out of the motor as well. You can have 85-90 ft/lbs torque and 80-85hp with a bit of planning and the right kit. go to nightrider and look at the evo builds on that site.
    http://www.nightrider.com/biketech/hdbuildstage3.htm if the link doesn't work copy paste into your browser.
    Look at the goal you want to achieve then work it backwards.
    PS-- bin the hypercharger as well....
    hi most of that was for drag racing , street or strip ?
  • wayne.craft
    wayne.craft
    Street use Bob, my little hotrod is getting out of hand.....
  • Jinx
    Jinx
    Thanks again for all the info, sounds like doing up the motor is the go and not replacing it.
    Jinx
  • houli
    houli
    Up the compression, work the heads and match the cam, your head guy will specify a cam, supertrapp exhaust, rejet the carb and hold on, ps bin the hypercharger, and if you ride with the throttle full on all the time buy a Hyabusa
