23" or 21" front wheel on 07 streetbob
  • gidgi
    gidgi
     G`day  has anyone ever put a  bigger front wheel on a 07 streetbob? bearing in mind the oem mid glide front end is there any dramas with wheel spacers or caliper shims ?or the need to change the gaurd position ? I also considered a complete wideglide front end from a later model aiming to keep the 49mm tubes any comments ,tips advice would be appreciated thanks
  • aztec
    aztec
     Hi, we recently fitted a 21 inch wheel to the front of a 2008 street bob but we laced the 21 to the original street bob hub using stainless steel spokes. Worked out no worries, guard still fits and looks pretty good too.
  • gidgi
    gidgi
    (The 21' will work, but careful going to small on the width. Cookie cutter rubber is not good for handling. You will need to think about putting in a lowering kit in the front forks to help with the handling.) cheers FYO I was looking at putting on a standard off the shelf 21" Tyre like on the Softails my front Tyre at the moment is standard 19" 100x H90 I recon by choosing a 21" Tyre with a lower wall height from a H90 it should not make a drastic difference in handling
