Air Horns
  • Sprocket
    Sprocket
    I have been looking for a good air horn.  Don't want a high pitched one.  What one do you use?
    I like the look of the howard horns but they seem to have lots of problems with brackets breaking.
  • Sprocket
    Sprocket
    Hi Crusty,
      Thanks for the suggestion and putting videos in too.  I had not given them much thought before but they dont sound too bad.
    Updated: I really wanted to buy the authentic air horn from meisterindustries.com/homepage.html shown below.  From their website the product looks very well designed with a lot of effort going into a quality product.  At the time I enquired I had a bit of difficulty getting a quote from the Harley distributors on his site but Tom Meister, the manufacturer was a true gentleman to deal with.
    Hopefully we will see them available from M&M Cycles real soon.
    I am also considering a few different air horns below from Metal Arts. www.metalartsinc.com/motorcycle%20air%20horns/accesories.htm
    Updated: This is the one I ended up ordering.
  • Hesh
    Hesh
     Hi Sprocket,
    Have just recently purchased and fitted the Pro Pad Minibeast 2 Chrome. The same one in the first vid that Crusty posted.
    There is another vid on youtube that has a before and after vid of the factory cowbell and the Minibeast 2 so you can compare the sound level.
    Am very happy with the end result.
    Hesh
  • Sprocket
    Sprocket
    Hesh,
       They look very good.  I ended up up ordering a metal arts compact magnum air horn yesterday.
    Thanks for all the suggestions guys.
    Sprocket
  • Rxes
    Rxes
     I took a couple of old electric horns out of my F'er, made a bracket to carry them, then added a relay tucked in behind and bolted them straight on, (after a lot of elbow grease, (bloody alloy)) a mate said that the sound reminded him of a freight train. They are not THAT loud, but they do make people jump. I blasted one guy who pulled out on me then braked hard, his face when his head spun was one of shock, expecting to see a truck or something, it was more satisfying than a mouth full of abuse.DSCF0885.jpg
  • Hesh
    Hesh
    It's Ok if you live in QLD as the Qld Transport & Main Roads dept states the following in the Vehicle Safety Standards:
    Motorcycles
    Note (3):   Dual air or electrical horns are acceptable but must be of a single note.
    So no Dukes of Hazzard style stuff
    Hesh
  • kmoulds
    kmoulds
    I have a pair of the old Mini Beasts which are really just Stebel Nautilus air horns and they work very very well.  I reckon I've casued a couple of heart attacks to some drivers, but they deserved it.
    Kymbo
  • Sprocket
    Sprocket
    Got the bike back from the dealers today after they fitted the metalarts compact magnum air horn, handlebars and auxillary lights.
    Crikey it's loud.
