Online: Nino
Stock Fat boy
  • JD
    JD
    Ok I worked out I can spend 5000.00 on the Fatboy in the next month so not sure where to start, So I am asking the question where to start with the budget ?
  • ronster
    ronster
    Hey JD
    air in, air out (noise), fuel management. The question is where do you want to stop?
    Ronster
  • Peter
    Peter
    Put a wide glide front end on it then rake it a bit then a 200 rear end 21inch front wheel. Oh hang on, thats my bike.
  • Hoodaman
    Hoodaman
    Lots of bling......oh hang on ..thats my bike....lol...
  • kingchops
    kingchops
    JD,
    High flow pipes & air-cleaner, and a Thundermax with auto-tune.
  • twincam88b
    twincam88b
    Get the wheels chromed/polished, that's the only thing I don't like about the Fatboy.
  • Paul.C
    Paul.C
    JD,
     Go the pipes and air. then look at comfort...seat and bars
  • JD
    JD
    think going the pipes and the air and going to pay the money get the ecm update and fuck it going to spend the 6000 to get the wheels I want you only live only once
  • JD
    JD
    i did type that when i was pissed Paul
  • Hoodaman
    Hoodaman
    I think i had  few with u last night too JD.....
  • JD
    JD
    I think you only live down the road from me too Hoodaman
  • toxic
    toxic
    ^^^^ as above ^^^^
    THEN PAINT IT BLACK
  • wildchild
    wildchild
    Not long finished my 08 Fatboy, did heaps...send me a PM and I'll send some pics
    WC
  • wildchild
    wildchild
    Haven't posted on the forum yet...is there a specific file format I can simply copy and paste into the text edit box. Or do I need to use Photobucket.
    WC
  • wildchild
    wildchild
    OK, I have worked it out, look for Custom Fatboy.
  • WA Fatboy
    WA Fatboy
    Fatboy is top for a gentle customisation!
