Online: speedzter
1200 nightster slip ons for 883?
  • Bunyip
    Bunyip
     Gdya guys,
    I posted a while back about fitting SE slashcut slip ons from an 07 883 for my 04 883. I was told that the rubber mounted sporty should accept the later models. I have an option on the exact ones Im after, but they are off a 1200 nightster. Im wondering if the same rule applies as the specs are pretty much the same except for engine size. Im showing my ignorance here, but can I use the 1200 slip ons for my 883? Thanks t this forum, Im learning all the time.
    Thanks in advance guys.
  • Bunyip
    Bunyip
     Awsome John, will will the heat sheilds fit? They are the black buckshot jobs. Im pumped. FINALLY some new pipes that wont break the bank.
  • 883n Harley Convert
    883n Harley Convert
    Hey Bunyip, McGregor is all over it.............. it will fit and will look pretty sharp mate!! Good luck!
