Severe rattle or knocking
  • Spider52
    Spider52
     Got a 2009 Road King, at idle it has a rattle that gets worse as it warms up.  seems to go away once on the move but it could be the case that the wind and exhaust noise cover it up. This rattle sometimes sounds like a dry bearing about to seize. Thre is no loss in power but I get funny looks when I pull up a the lights, not that I'm riding it now but coming back from Batemans Bay it got louder.  Have taken off the primary cover alls OK. Hard to pin point where exactly the noise is coming from.  Anyone had similiar issues?
  • Spider52
    Spider52
     The rattle is at no specific speed, rev it up and it just rattles along at the same pace as when idling.  This is comforting in a way but annoying.  I'm about to go over the exhaust and check all fittings.
  • Spider52
    Spider52
     Thanks Ray, hope you're right, good excuse to get a new exhaust system.  Getting too hot now I'll check it out later.
  • robert65
    robert65
    are you sure it isn't the compesating nut , sounds like it. The noise will go away under load and at idle will knock . just fixed mine last week .
  • HogBag
    HogBag
    Check the exhaust flanges are tight. Grab a torch and look around both exhaust ports for leaks.
  • numbers
    numbers
    try raising the back wheel off the ground and spin it - if it makes a grinding noise then its possibly within the primary or tranny
  • Spider52
    Spider52
     Thanks for all your comments and recommendations.  Blacktown Harley, where I bought the bike, had a look and eventually came to the conclusion that the roller bearing for the cam are f^%^$%d and because of that the cams are F&%^%$d and it will cost about $1500 - $2000 to fix. Harley Aust will not have a bar of it because it is listed as a race tuned engine.  I got a 103 with a stage 4 set up doen to it before I picked it up, the up grade wasfor more grunt not to race. Bit disappointed with HD response seeing I have only done 27K, 2 months over the warranty period.  The previous bike I did 100K no problem, the V Rod still going strong but this Screaming Eagle is screamin.  I'm starting to wonder if there is a Victory Forum.
  • dc4prez
    dc4prez
    I've had similar crap from HD Australia - The proceedure is to ring HD (get the number from HD america website Customer care in US - have your VIN for your bike handy, talk them through what HD Australia told you, they will give you a case number. give them your email addy and you will get apologising emails from HD australia
    dc4prez - hey and try it it has worked for me on 3 occasions
  • HogBag
    HogBag
    That Sucks
    The cam bearing should have been replaced with timken b168 bearings when they done the rebuild. I hope they caught this before the needle bearings went through the motor. Harley don't mind selling you this stuff and the dealer will tell you your under warranty until the shit hits the fan and they all back out of the deal. Like I said a dozen times on this site if you fit a screaming eagle race tuner with screaming eagle race parts your on your own unless the dealer puts it in writing that he will cover all costs if she blows. Take the bike to a different dealer or a independent shop who will stand behind there work and get them to check it out.
    Good Luck Spider.
    HB
  • Spider52
    Spider52
     Thanks , I'll try that.  As usual looks like you need to go straihgt to the top and don't beat around with the fodder.
  • Humbug
    Humbug
    Have you talked to HDA or just your shop? You can ring HDA and talk directly with the warrenty bloke,which I had to do to sort a problem. Or If already done,as mentioned before ring HDUSA
  • Spider52
    Spider52
    ALLS GOOD,  bad rattle was only the cam roller bearings shitting themselves in the front cylinder.  bearings disintegrated after wearing away the case harding on the cam.  Around $1800 worth to repair, new bearings and cam shaft.  Blacktown Harley came to the party with the parts, all I had to pay for was the labour.  Alls nice and quiet till just today, now the primary is making hell of a noise in idle while clutch is out in neutral and while in gear and engauged.  One thing after the other.  Anyone want to buy a 103 stage 4 Road King with heaps of extras?
