charging issue
  • terroristone
    terroristone
    Hey Jim, here are some pages from the service manual for you, with these you should be able to get it sorted....let me know how you go.
    Regards Andrew
  • terroristone
    terroristone
    Looking at the wiring diagram, check that the voltage reg has a clean ground.
  • wazdog
    wazdog
    Do make sure the regulator has a good clean constant earth where it mounts. Spiking kills them pretty quickly.
