Extending wiring harnerss
  • whitey3177
    whitey3177
    G'day fellas,
    I'm looking at doing away with my cow horn bars in favour of a set of 14" apes with 1" risers. I have purchased the longer clutch/brake cables but am told that i have to also extend the electrical cables. Any idea what size electrical wire is required for extending the harness?
    Thanks in advance guys
  • 883n Harley Convert
    883n Harley Convert
    Hey Whitey, you can buy pre-fabricated kits to that plug straight in! Burly Brand does some, but they're a little pricey...............google it and you'll definitely find something!
  • Gidgee
    Gidgee
     Rollies has the harnesses to mate
  • Dan
    Dan
    I got my last wire kit from eBay
    Less than $50 delivered
  • blueystar
    blueystar
    thats all i did got some wire from a auto shop stagged the cuts in the harness and put in 6" and tape it all up
