CLEAR LENSES
  • condor
    condor
    hi people!
    does anyone know if you can get clear brake lenses for the iron 883?
  • 883n Harley Convert
    883n Harley Convert
    Not sure about clear, but I have a smoked set that aren't too bad!
  • TC883
    TC883
    Condor, I think you will find the combined brake/tail/blinkers are a sealed unit. You can't change the lenses on them. Sorry. TC
  • terroristone
    terroristone
    i have seen a few bikes in the states with them, but its not something i have looked into....ask around here http://xlforum.net/vbportal/forums/index.php I'm sure these guys will know.
    Regards Andrew
    edit :   looks like you are out of luck on the rears mate   http://xlforum.net/vbportal/forums/showthread.php?t=738620&page=2  the UK/AU rears are indeed sealed LED ones, the US have non LED ones, the difference being (i think) is that they use the parker/brake as an indicator as well (so 1 less light needed than us).
    I have Clear LED Lay Downs $65.00 on Special  VPW 03 8405 9212
