LED Turn signals & Running lights
  • Rick1310
    Rick1310
    Custom Dynamics Bullet Style Complete LED Turn Signal Conversion Kit
    I know have LED blinkers on the front with smoked lens & convert the rear to Run, Brake & Turn signals with smoked lens. They work well & look great, they go well with the HD LED tail light that I already have. The rear are set up as the outer ring of leds are AMBER & the inner cluster are RED for run & brake.
    All up it took approx. 2.5hrs to fit them with running the wires & retape them in with the standard harness but well worth it
    Here are some You tube links
    http://www.youtube.com/watch?v=1Hi2PgRlf7w
    http://www.youtube.com/watch?v=7OmNiREgGC8
  • FXSTC 09
    FXSTC 09
    Curious to know if they are 'E' marked for ADR?
    Cheers Troy
  • Rick1310
    Rick1310
    I do not know but I will find out one way or the other I think. But if you look at the new Harley's it the same sort of set up except for the normal tail light.
