2001 fxst TSSM/Smart Siren upgrade
  • SillySid
    SillySid
    I've just installed the HD TSSM & Smart Siren kit to my bike and it followed the destructions but I still cannot get it to work.
    I have checked the FOB battery and its 3.1 volts. The symptoms I have are below:
    1. No Blinking blinkers
    2. No low beam (have high)
    3. No Horn
    4. No Brake lights
    5. Cannot start the bike
    6. No beeps or screams from the sirem
    Everything looks normal with the dash; (that is the little KEY led  comes on and cancels after 4 secs).
    Is there anyone that can help please.
    Cheers Sid
  • HogBag
    HogBag
     Has the tssm  been armed with a code ?
    Here's the trouble codes for a 2001 tssm
    Checking For Harley Trouble Codes TSM/TSSM
    To diagnose the TSM/TSSM observe the behavior of the turn signals.
    If the signals flash six fast 4-way flashes shortly after key on,
    then an error code has been logged.
    Code Types
    There are two types of trouble codes:
    Current and Historic.
    If a trouble code is stored, it can be read using TSM/TSSM Diagnostics.
    Current
    Curent trouble codes are those which are present during the current
    ignition cycle.
    Historic
    If a particular problem happens to resolve itself, the active status
    problem is dropped and it becoes a historic code rather than a current code.
    Intermittent output shorts can become typical historic codes.
    Historic codes are stored for 50 ignition cycles.
    It is important to note that historic codes will exist whenever the system
    indicates the existence of a current fault.
    Notes
    *If the turn signals flash six four way flashes shortly after key on, it indicates an error code has been logged sometime in the last 3 ignition cycles. On vehicles with TSSM, the security lamp will also light for eight seconds after the bulb check if historic codes are present.
    *The security lamp will stay on if current code(s) are set. If a historic code is present, the security lamp will light for 50 ignition cycles or until the code is cleared manually.
    Invoking TSM/TSSM diagnostics
    1: Set Run/Stop switch to off
    2: Turn ign key ON-OFF-ON-OFF-ON
    3: Press the left turn switch two times and release.
    *The signals flash 2 times for a Domestic TSSM
    4: Press the right turn switch 1 time and release.
    *The signals flash 1 time.
    5: Press the right turn switch 1 time and release.
    *The signals flash 2 times.
    6: Press the right turn switch 1 time and release.
    *The signals flash 3 times.
    7: Press the left turn switch 1 time and release.
    *The signals flash out the trouble codes.
    There is a 1.5 sec pause between flashes to distinguish between 1st and 2nd digit of codes.
    There is a 4 second pause between codes, then it will loop and repeat codes.
    If the light comes on for 4 seconds after invoking test then goes out for good,
    there are no codes stored.....test over....turn ignition off.
    Wait at least 10 seconds
    before turning ignition on again.
    8: To clear codes (after repairs) press and hold left turn switch for 4-5 seconds at end of test.
    * The signals flash 2 times to confirm your request.
    Codes
    11= Battery voltage high
    21= left turn ouput fault
    22= Right turn output fault
    25= Ignition enable output high
    31= alarm output low
    32= alarm output high
    34= starter output high
    35= accelerometer fault
    41= Ignition switch open/low
    Possible causes
    11= battery voltage >16.0v/battery charger used/voltage regulator fubar'd. (pin 1 / Bn/Gy)
    21= bulbs/shorts/bad connections if no voltage on pins 5 or 6 with 4ways on TSSM FUBAR'd
    25= should be no voltage present on pin 10 with key off. (Lt Grn/Gy wire on TSSM)
    31&32= Middle pin on siren goes low voltage to fire alarm, high voltage to stop.
    If the siren responds with 3 chirps instead of 2 the siren battery is fubar'd.
    Pin A (Bn/Gy) is positive voltage downstream of the 15amp security fuse.
    Pin C (Bk) is ground from pin 12 (Bk) on TSSM
    34= Starter relay and coil are grounded via TSSM when disarmed and ignition on.
    This code means the ground is from someplace else...short/hot wired..etc.
    Starter relay could be fubar'd (voltage present on pin 9)(Tn/Gn) when not starting engine.
    35= TSM/TSSM Fubar'd... bank angle and tamper will not function when this code is set.
    41= Signals will not flash due to shorts, bad connections/wiring/bulbs/TSSM fubar'd
    More notes
    *If the siren Chirps 3 times instead of 2 this means time for a new siren battery.
    *There can be codes set in the TSSM without any visual indications ie: Security lamp/ Signals
    *There needs to be 12.0vdc available from the main battery
    *There are 4 sensitivity settings for alarm activation, with regard to motion....lol
    *There is an Auto Arming feature available, all domestics are shipped with this disabled.
    *Always disarm the TSSM before disconnecting the battery, or siren will activate.(If present)
    If auto arming is activated, you have 30 seconds after disarming to pull the fuse
    to accomplish the above.
    *Tampering or problems with the security light circuit activates the alarm for 30 seconds.
    *Storage mode time is selectable, and will shut down system at 30,60,or 90 days, or never.
    Key fob will not work after shut down. Turn ignition ON to re-activate, the alarm will sound
    if it was armed prior to storage mode shut down. Use the key fob to disable the alarm.
    *IF you render the key fob useless and did not program a personal override code in the TSSM,
    you are not only buying a new fob, you are buying a new TSSM as well.
    Once it learns a key fob, it learns no more..lol
    TS/TSSM Pinouts
    1= Battery (Bn/Gy)
    2= Ignition (Gy)
    3= VSS/Serial Data link
    4= Security indicator (Bn/V)
    5= Left turn Feed (V)
    6= Right turn Feed (Bn)
    7= Right turn switch input (W/Bn)
    8= Left turn switch input (W/V)
    9= Start relay Control (Tn/Gn)
    10= Ignition enable signal (LGn/Gy)
    11= Alarm signal (Lgn/Bn)
    12= Ground (Bk)
  • SillySid
    SillySid
    Thanks for the reply's.
    My ride is a Carby  2001 fxst.
    The blinkers dont flash at all to tell me whats going on.
    I'm going to plug my TSM back in just to confirm I havent created a silly fault.
    Cheers Sid
  • SillySid
    SillySid
    Woo Hoo ! Sorted !
    Thanks HogBog, I sat down and read your proceedure and decided to hunt for the 'no blinkers issue'.  I found the ACCY / Instrument fuse was blown. I'm sure I checked it last night, but I guess I was cranky & thirsty.  Once I replaced the fuse, the alarm sqeaked and the blinkers worked.  I then grabbed a beer and really really persistantly followed the destructions and it finally accepted my FOB . Then I decided to try and crank it over, but the starter just rattled at me. (now this really sucked as I have a Cetek which I always use on the battery, and the Battery was 13.6v). Anyway I was lucky enough to borrow another battery and it burst into life .
    So the lessons I have learnt are: 1. Be thankful for this Forum, 2. Never work on a bike in the dark, 3. Always be anal (can I say that word?) when cleaning battery terminals.
    Thanks Fellas, Cheers SillySid
  • SillySid
    SillySid
    Hi Hogbag,
    Mate, I'm trying to 'Auto Arm' this TSSM. I took the bike to a Dealer but his Scanlyser doesnt recongnised it.
    Can you advise if I can manually do it with the turn signal buttons?
    Also to destructions state when connecting the fob: 2 flashes means USA, 3 flashes International, well mine flashes 4 times....
    does that mean that its from Tasmania?
    Cheers Sid
