howard horns
  • softail09
    softail09
    I had some Howard horns sent over from the states NOW THEY WILL HEAR ME  there called duo hornsput  on my custom softail will post a pic  soom but very loud .
    Apart from the freight the price wasnt to bad.
  • Sprocket
    Sprocket
    Have you fitted them yet?
  • Burraburra
    Burraburra
  • SoftailSteve
    SoftailSteve
    http://www.howardshorns.com/
  • softail09
    softail09
    sorry mate havent been on for a while
    cost more for the freight than the horns but it what i wanted   $300 odd us if you know some over there you could save heeps freight was $150 but here in about 6 days
    Instalation was all good the compressor goes behind the old horn cover and they sound great
    Cheers Smokey
  • softail09
    softail09
    yep i will asap
    cheers smokey
